 fifo1109 píše: Zdravim, mam sv 650s 2009 a potreboval by som tubu z lavej vidli kedze sa mi ulomil od tuby drziak na brzdic. Chcem kupit pouzitu kedze je to o dost lacnejsie ako nova, len bude pasovat napr od rocnikov 03-08 na moju 09 ? Nic sa tam nemenilo ?
 Chcel by som kupit len tubu a do nej dat pruzinu a tie ostatne diely z mojej 2009ny.
 POjde to ? Dik
 '09 ma cierne tlmice inac tam nie je rozdiel
 2003-
 New design. Slightly different bottom end, oil cooler, EFI, temp gauge, digital speedo. Slightly more power, mostly due to hotter cams.
 2004-
 Lower subframe. Subframe now aluminum.
 2005-
 Narrower radiator. Different foot pegs, rear sets and foot controls to accomodate the lower pegs. Black frame, wheels and lower fork tubes.
 2006-
 Some minor electronics upgrades (or was that 05?). Tank recall on prevoius 03+ CA models (or was that also 05?).
 2007-
 Dual spark plugs. Optional ABS.
